iluv83vettes
- Houston
I did the WJ conversion and added an Artec truss with over the axle track bar bracket. For the frame side I used the Ruffstuff outside the frame mount to get the track bar the same length as the drag link. The Ruffstuff mount doesn't drop down as far as some of the others, so to have the drag link parallel to the track bar I need a less drop pitman arm. From some searching, it seems the options (I haven't measured how much less drop I need) are the CJ, waggy (I'm guessing these are full size waggy arms), or the YJ/TJ from flat to 1" less than stock XJ.
I was wondering if anyone has been able to pick these up locally from typical auto parts stores or do I need to order one.
Also, if anyone is running the Ruffstuff outside the frame track bar mount, were you able to get a sway bar to work? I have a few options on the axle side to weld on the mounts but I get interference with the mount.
