AnthonyZ28
- Hallettsville, Texas
So the way you check your AX-15 is it has a 15/16 plug on the upper driver side about 5 inches up from the bottom and I would crank down all the bolts holding your T-case to your trans ( I say this because I had the same leak) and it will slow it way down or stop it .
By crank it down you mean tighten up. Right?
