blondejoncherokee
- sacramento
so after reading that thread on pirate im even more confused . which shaft is the best out of the under 600$ range? i see evidence for all of them.
i was surprised to see so much talk on there about making the pinion the weak point when upgading everything else on an axle. it also gets to the point : its still a d30. for all the money we throw into our 30s we could start building 60s...
yes fullwidth once its not my DD lol
Ten Factory is what I run and after the GREAT customer service it is all I would recomend anyone to buy!
Ten Factory is a ten year warenty!!!
Nothing wrong with a full width daily driver. Mine is, and I love it, drives great down the freeway and handles better than stock. Build it right and your good to go.eace:
No, my rear is 35 spline, my front is only 30 spline with 27 spline warn outers.You running 33 spline shafts with your 37s?
after reading this thread , when i finally get the cash(tax return time) ill be buying some ten factory shafts front and rear it looks like and
along with front and rear trusses from tube to tube, and tube to housing... just gotta find someone with a jig and alot of experience welding to cast
If you're gonna put deep gears and big tires on a 30, you should think about a full case locker (or even better for longevity, a full case open carrier... if such a thing even exists for the 30.)
Housing flex or carrier flex will effectively give you a really lousy gear setup under load, which results in chewed up teeth.
I have a lunch box locker inside my full case open carrier.
What kind of Diff cover you have?
I really think the big think fat diff covers help a lot.
