since this thread ive been reading up on ten factory axles all over different forums. i can guarantee you that if i had an extra 500 id buy em right now. a ten year warranty? damn thats sexy.
the underlying concern in the back of my head is that when you go to chromo shafts and u better joints in the 30 without trussing it that you make the pinion in the 30 the weak point now, especially with 4.88s . you have 4.56s.
in the back of my head my justification for running stock shafts other than i cant afford the 4340s is that id rather break a stock shaft than take out my front pinion.
next is a truss for me.
i think the thing is that im trying not to kid myself, no matter what i do to the front, it is still a dana 30 . it has d44(297 or 760) sized u joints, we can get chromo shafts, and we can truss it, and convert it to wj knuckles and get dual caliper pistons and high steer. but we still have a 7.5" ring gear and a smaller housing.
it seems a truss and tacking the u joint caps should come before chromos if youre concerned with the pinion becoming the weak point bottle neck. if youre concerned with the axle shafts themselves breaking then chromos are a great idea. if youre concerned with u joints then why not throw some 760s in yours (if you have the 297 joints, ) and the truss will help eliminate deflection in the housing. i also think the ruffstuff covers work very well in solidifying the housings on the 30.
my fear is finally forking out the $500 for the shafts and then grenading my front end because i didnt truss it...
