ajeeperwannabe
NAXJA Member #1367
- Burlington NC
yeah seen 92 on a sign at lunch. a scorcher out there.
Right there with you my Friend. Friend is helping with the mod and fab of the new TB bracket and TB. I'm torquing and checking all the new bolts and old ones. Got to weld on shock mounts and see how the flex is and weather or not I'll rip a brakeline or not!woody said:I am still down in the grease pit tooworking slow & easy without a spotter nearby.
Dammit if this AC doesn't suck a boy in. Each smoke/water break is lasting a little bit longer. It's up into the 90s by now, so in no hurry to get back after it.
Lotsa Fun
rredalty said:Still have to run the OBA setup, pull apart the rear leaf pack and get it working better, weld the front diff and install the posi-lock and try to find a tie rod that is straighter than the one that is currently on there.
rredalty said:OBA...Check, Pull rear leaf....Check, Weld diff and install posi locker.... too hot outside, Find good tie rod.... not done, just re-aligned.
Do I need to bring one? If I can find one? Let me know b4 tomorrow.shortxjdoug said:haha my tierod got bent very slightly up today don't know how i managed that :dunno:
Ghost said:Do I need to bring one? If I can find one? Let me know b4 tomorrow.
Please do!!!! I'm in need of one pretty bad.Ghost said:Do I need to bring one? If I can find one? Let me know b4 tomorrow.
rredalty said:Please do!!!! I'm in need of one pretty bad.
rredalty said:I know it says an adequate spare is required, but I have none. Will that prevent me from being able to ride with the group? If it makes any difference, I have plugs for both inside and out to fix a hole and I'm also running OBA.
