Whatcha need to get done before Winterfest?
Install Zip locker
wire up compressor
fix leaky pinion seal(during locker install)
Weld shock mount back on
Bolt t-case skid back on
I was planning on doing a cage but I don't think that's gonna happen.
Have to do stiffies and replace the rockers with tube. Design 3 link bracket....lift it a little, add relo brackets, build rear recovery.....I just don't feel like going to garage.
JEEP:
-Frame stiffies
-Rocker replacement
-Tie 1 and 2 together
-Build a new bumper
-Install winch
TRUCK:
-Build some type of shelf in the back for my heater to sit on
-Take the topper off and put new tape on it to seal it up
-Cut a sheet of OSB to lay in the bed so the air matress doesn't get cut.
-Put the heater back there when we get some cold weather and see how well this topper holds heat.
Bumper will be done Monday.
Then need to get the jeep to smash hole for rocker and stiffie install.
Still need to do everything on the truck.
It's gonna be hard to choose the best jeep build this year. Everyone is upgrading!
Trailer back there too...
mac 'might be there a while' gyvr
I didn't plan on doing anything to the jeep as it has been running good all year since last winterfest.
but then as if clockwork every year, 1 month before WF the brakes started acting up. Looks to be only a sticking driverside caliper, hope it didn't waste the pads by the time I noticed it.
JEEP:
-Frame stiffies
-Rocker replacement
-Build a new bumper Doneish want to get a hoop added but not mandatory
-Install winch Doneish need to put solenoid box on and wire.
TRUCK:
Its coming fast!!! Need to get my junk to Smash Hole HQ and do my rockers.
Tow rig:
-Water Pump or buy more coolant
-air up spare tire
-grease the hub bears on trailer - Done
Jeep:
-replace bent wheel - Done
-confirm spare tools and parts are in jeep
-fix whatever my brother breaks this Sunday - Replaced back windows with plexiglass, brother broke them - Done
-Check lower control arm that is tweeked
-clean the jeep, well see
-"Nut-n-bolt" the entire jeep at my brothers shop
Install Zip lockerDone
wire up compressor
fix leaky pinion seal(during locker install)Done
Jeep:
Install 231 - done!
Figure out rear drive shaft
Figure out front drive shaft
Install long arms - done!
Install coils - done!
Limit straps for front
Re-do bumpstops
Install new winch -done!
Install longer front brake hoses - done!
Install shocks - done!
Install track bar and bracket - done!
Alignment
Weld xmember - done!
Trans filter
Fill tcase - done!
Steering
Tcase shifter - done!
Skid plate - done!
Beadlocks
Fuel cell
Tow pig:
Install transmission
Change oil
Install super mega killer hitch
Camper:
Install dedicated fuse block for the heater
Seal roof
Fix the jack mounting points
Rip out toilet and replace with a portable
Change/check fluids - Almost done, Ran out of grease.
Adjust tracbar to keep mount from hitting my coil spring - Done
Bumpstops front - Done 2x2 box tube.
Remake a steering stabilizer mount - Itll work.
Cb antenna - Done
Fix oil filter adapter leak - Done
