What year waggy had 5X5.5 bolt pattern?
Heep
Nebraska
Going to see if I can just swap the hub and rotors out.
Here it is again...
Below is a list of the years of the spindle and knuckle you’ll need for a Chevy disk conversion to run Ford hubs on it. Do note all the differnet knuckles!
BOM......Year........Truck..............Spindle........Knuckle......Inner Wheel bearing
Chevy Truck
603374...73..........K5 or K10..........706528x......706135x......705110x
603354...74-75.....K5 or K10..........706528x......706135x......705110x
603706...76..........K5 or K10..........706528x......706484x......705110x
603676...76 1/2....K5 or K10..........706528x......706116x......705110x
Jeep
603462...74-76.....Wag & Cherokee..706528x......706135.......705110x......Disk Brakes ONLY!
603633...75-76.....Cherokee Chief..706528x........706135.......705110x
603646...74-76.....J10 Pick-up.......706528x.........706135.......705110x......Disk Brakes ONLY!
Note, last BOM for J10 may be 603464.
Ford Hub and Rotor you want is 1976-1985.
thanks Ill do the conversion with the Ford and chevy parts
Re: Re: What year waggy had 5X5.5 bolt pattern?
Hunter-Lynchburg said:
IIRC all waggys had 6 lugs (yota/chevy bolt pattern)...not sure about j trucks though.
Hunter
Nope, some of the old (I believe 70s) had 5, but they are pass drop.
Not sure exactly when or why they switched to 6 lug. I do not believe it was at the intro of the M20, because you could still find 6 lug D44 rears.
