What was done to YOUR rig(XJ/MJ) today MECHANICALY????
Re: What was done to YOUR rig today?
Thought about my tcase situation. New plan is to tear into the old tcase and see what kind of loving it needs. if all it needs is a rebuild and a chain, ill order a rebuild kit and grab the chain out of the newer 242 that I was going to put in.
Ok now I know why my jeep has been running so bad. The shop I took my jeep to didn't seat my CPS correctly, I just scanned it it's throwing codes for my cps and ignition coils
I picked up a set of 4 Moab wheels for the XJ. Then the day after I bought them, I saw a set of 5 in better shape with more tread :mad:. Ohwell.
I started planning my engine swap.
Where might you have seen the other set? Are they still for sale? Link?
They were on the Tulsa craigslist. I did a quick search for them but they didn't show up. I guess they have been sold. I check it pretty regularly though, I'll pm you if I see them again.
My truck got sammiched in an accident on 75 today. wish my jeep was ready to be driven. :-(
I noticed that mine was not only leaking oil, but antifreeze also. Too cold to do anything with it so I went back inside.
How about a pic, is it totaled?
what magimerlin and i did over the last two days....
this is our redneck engineering way of getting shackle to line up correctly...lol
done...b-4 we took off jack...
kinda finished...ended up moveing back one hole for little less angle
OK, XJ looked like a dragster so went to 4wheelparts and picked up 1-3/4" coil spring spacers...leveled out nicely.....
Then we or i mean jay fixed my loose drop pittman arm....for some reason there wasent enough washer to get it to seat properly so it moved a little..so he welded spacer to pittman,prob solved...then he discovered my pass tre was TOAST....so talked wife into upgrade soon...lol
So how was ur thanksgiving....
Rich,
Sorry I missed you guys today. BTW, that's exactly how I ended up lining up my shackles. Well, that and some big heel bars.
Anyways,
I tore open my rear end to fix that pinion bearing from the fall trip. Pinion is toast. :(
Air bags went off. Sceptical about its fate.
Rich,
Anyways,
do u have locker in that 8.25? if i member right u dont....anyways will keep eye open for axel for ya.....have that bag for u also
Sorry for your truck, hope everything turns out ok. 75 is the quickest way to Dallas for us so I know how big a mess it can be.
