Ecomike
NAXJA# 2091
- MilkyWay Galaxy
OK just came from town. Last time I drove it It was overheating. Bad thermostat I think. Replaced with OEM. The temp gauge, if accurate, was reading lower than normal bit less than 190 all the way. No problem... got home and smelt antifreezepopped hood and it seems steam is escapeing at the radiator cap is that normal? Also felt top hose... was very hot but seemed like hard / full. Am I missing something or is this normal?
You should leave the cap off and run it till the T-Stat opens, then fill it to almost the top then after the foam stops from trapped air getting out fill it to the top and cap it off. I am assuming it is not a renix since you mentioned a radiator cap?
Replace the cap, but test it at the counter with a pressure tester (they rent them at the parts stores) before you buy it. Some are bad right out of the box.
If a new cap and proper fill/degassing does not solve the problem and there are no leaks you may have a bad radiator, water pump, belt, head gasket leak, bad fan clutch, is the E-Fan working????, engine running too lean, and lastly a possible exhaust leak blowing on the block.
