- Houston, Tx
Got the last couple items I needed for ROM
Just need to hook up the CB and re-wire my switch panel this weekend
Use a somewhat common nut splitter tool? Or replace the u-bolts (I assume it is the U-bolts on the leaf springs?) and just use a Harbour Freight sawzall (about $30 or less on sale) to cut the old bolts off in about 30 seconds each. Awesome tool the sawzall!!!!
HELP!!!!!!!
Calling all readers here. I need help!!!!
Got the old ball joints off the 89 2WD Cherokee. Don't ask how. Got the top ball joint installed. OK ask how, LOL.
I went to 5 local parts houses and rented 3 different brand ball joint press tool sets and accessories (cost $350 in deposits), made about 10 trips...and the closest thing they have to install the lower ball joint is too big by about 1/8" in diameter and so it turns itself side ways just enough to not work properly. Got the lower one installed about 70% but the ball joint edge is too buggered now to use the loose tube for the bottom to complete the install. Does anyone in the local Houston, South Houston, League city and surrounding areas have the right tool for pushing the bottom of the Jeep ball joints on for a 2WD, 1989 XJ rig? Not sure if they are the same as the 4WD, they may be. A case of beer is waitingfor the first to show up with something that works
I was able to rent the correct tools from Oreillys, no problems. But I'm not sure if the 2wd is any different.
Tried to figure out the rattling noise coming the front end on my jeep again. Been around for a long while. Only rattles when driving it and goes away when putting any pressure on the brakes. Took the front passenger wheel off and after Some tapping around with a hammer, I noticed the caliper moves a bit. Looks like I need to replace the pin and boots or heli-coil the mounts. I'll figure it out tomorrow.
Did you rent just a standard kit or get the 4WD accessory kit too? I think the one I went to was out of the 4WD kit. Could not find anyone in S Houston/Pasadena with the 4WD accessory kit. Autozone has non anywhere and Napa has no rentals. The best kits I saw were at Advanced.
Lol....anyone got a spare hd trackbar mount? Long story......
