- Richardson, TX
Re: What was done to YOUR rig today MECHANICALY????
Got the rear springs I ordered.
Got the rear springs I ordered.![]()
what size springs did you order?
Yes I am, what do you want?You going to ROM? I've got a set of brackets (no hooks) I can barter out. C4x4
Rustys 3.5"
what are you trying to net?
My set of Rusty's 3" springs have served me well for over 10 years.
I guess I'm too Jeep ignorant, what are those things?
You want the brackets. The extra flex and ride improvement is worth it!
but from what I've gathered, they don't work well with stock shackles. And if I used longer shackles the rear end will end up higher than I want it
they work fine with stock shackles, the only problem you MIGHT run into is needing to trim the rear portion of the lower box after you have set your shackle angle. Listen to JR, you want to run them
