A lot of guys around here use trailer axle setups. Rockstomper here in Colorado carries them. They need to be the heavy duty spindle. The constant vibration and stress has yielded several failures of the normal spindles. You would think they would be stronger than that, but I guess the stresses are higher than you would think.
The setup Rockstomper has is a modified trailer spindle with bearings and housing. You should be able to get an idea from that. Their prices are very reasonable and will save you a TON of fabriction hassles.
