goodburbon
- Westcliffe Colorado.
I'm just making a point about social behavior.
I'm just making a point about social behavior.![]()
Of course it is
PEMDAS
M comes before D, so yep 2 is the answer. Anyone that doesn't think so is generally a self-righteous a-hole when they answer.
You don't know how to PEMDAS
Multiplication and division(no, M does not come before D, its which ever you encounter first working from left to right
Doing MaD or AaS in any order it is incorrect as well.
Take this part of the solution: 48/2*12
If it was done in any order you could do 2*12 first. However that wouldn't work.
48/24
=2
which is incorrect
You just said that it didn't matter in what direction you worked the equation. I.e. L to R vs R to L. That is what I did, which according to you should have worked, but it did not.You did it wrong. You changed the problem when you changed the order that you processed the numbers.
The examples you gave are different from doing the equation in any order.48/2*12 =
48*12/2 =
12*48/2 =
12/2*48 =
1/2*12*48 =
288
Yes, M and D have the same precedence however, doing the equation in any order will give you different results.The reason M and D have the same precedence level is that the order that you process them doesn't change the result.
Talyn;245308713You just said that it didn't matter in what direction you worked the equation. I.e. L to R vs R to L. That is what I did said:No, no, no. :banghead:
I'm not talking about how you type it in to a calculator. That's a separate issue. I'm talking about the math. How are my example equations not showing that left-right order doesn't matter?
24*12 will give a different answer from 48/24.
? Well I'd hope so...
48/24
=2
which is incorrect
If done correctly, left to right you get:
24*12
=288
