What rear end and why?
Jump This said:
What are you running and why?
I replaced my D35 with:
Currie X HD 9" housing (shaved)
RE anti wrap perches
Raised shock mounts
35 spline chromo shafts
Explorer disc brakes
Billet pinion yoke
True hi-9 third member
4:86
ARB
spinning 33x13.5x15 Toyo M/T on 15x10 forged Centerline's w/4"bs
WHY? As much as I loved the open D35, I wanted a set up that I could lock and not have to worry too much about knocking the grease fittings off the drive shaft. At the time I could not find flush mount fittings.
No problems so far; no plans for changing the axle anytime soon. The Toyos have a section width of 14 1/2", that's why I'm running 10" rims. I'd like to go to a narrower rim but then I'd have to go to a shallower bs, that would put me pretty much back to where I am now width wise.
