What does your rig weigh?
kid4lyf said:
My motto:
Whenever you have to decide between using 3/16" or 1/4" plate.
Go with 3/8".
Nothing exceeds like excess
My motto:
Whenever you have to use 3/16", go with 11ga.
Whenever you have to decide between using 3/16" or 1/8", go with 14ga.
Paul
Paul S said:
My motto:
Paul
Yes, we've seen the results of your minimalistic motto on broken Panhard mounts. :D
Good memory:)
But I think that had more to do with my welds. In hindsight, going minimalistic on a TB mount is probably not smart for ones first ever structural welding job.
Paul
kid4lyf said:
My motto:
Go with 3/8".
that's why my new lower links are 2" .385 wall. The 1 3/4" .250 bent at the adjustment spud and then later on the link itself. The 2" ones have had a good thrashing and are still straight.
4800 with me in it ready for the Hammers(spare front shafts, spare rear shaft, spare drive shaft, tools, full tank of gas).
Ouch!......that's sorta.......portly :shocked:
mine was 4460.
OT just stfu and get your sawzal out and cut some more crap off that thing.
Soon you and Paul will have to check into the hispital for xjannarxia!
4143
LF 1206
RF 1124
LR 868
RR 945
Half tank of fuel
CO2 tank
Spare Tire
Hi-Lift
Tools/shovel/axe
not including driver and pass or related gear.
The new diet worked wonders. I'm down to 3540 lb trail ready.
aAlittle more work and I should make it to get under 3500.
My front to rear is way off though. 2320 front 1220 rear
Xjarexial...... :D
I try to stay slim and trim, but anyone
less than 4000 lbs.....
hard to call those things XJs!!
Okay, thats enough David and Paul bashing,
those guys can go places I can only go in
my dreams!
Rick R:sunshine:
Jump This said:
Xjarexial...... :D
my dreams!
Rick R:sunshine:
or their passenger side seat :laugh3:
Geepfreak said:
My cruiser weighs sixteen hundred kilograms.
:laugh: 6 days later and i finally get it:D
just went and wieghed mine...
1997 sport
4320#
5X 33's, warn front bumper, Poison rear swing out, rockers, gas tank skid, roof rack.. junk in trunk... oh and the hil ift...
still have to add the winch eventually...
so what's the coilover/links report? have you got them dialed in? mine has probably about the same weight bias and I've never noticed it to be a disadvantage, it seems to help it climb and I never find myself going down crazy ledges.
It seems to work. Could be much better though.The springs are to way to soft. I was hitting hard in the woops. Plus on the trail I was using all the spring as well. Time for some stiffer ones.
One the bad side, they almost put me on my lid in the same spot Ron went over.
