What do YOU need to do before NWFest 2010 ?
Rich, I will more than likely stop by this weekend to check out your replacements, thanks! I need to visually see what I'm doing for sure. And since my welder isn't that big, I can only get things generally in place at my house...then I have to drive to a friends to burn it all in.
I have plenty of lift for the tires now, and I trimmed plenty (I think/hope) when I built the rig...my biggest worry is my front shafts. My steering/suspension is all pretty set-up, but I'm lacking alloy shafts...which I'm hoping won't be an issue if I keep the locker turned off for a majority of the trip.
I couldn't pass up 35" 80% tread tires with rims for $80.
~Scott
Yeah, thats cheap and you already have 4.88's right? we'll be around all day so just give me a call.
I think i can safely update mine now...
1. finish exo - DONE !
2. Tires - Ordered Should have by the weekend :yelclap:
3. Bedline the inside - DONE !
3.5 put it all back together - Working on this still...
4. left over steering issues still need some attention - This weekend
5. seats and harnesses... if i have any money left from #1 and #2 - Not in the budget
Lift DONE
Tires DONE
>Included Quick Discos, LCAs & Shackle Relocation Brackets
Front Bumper
Rear Bumper DONE
Winch
Roof Rack
Lights, lights, lights, lights, lights.
Sliders
Xfer drop DONE
Stereo
Doorless mod Eh?
Sleeping platform/interior storage mod(?)
Lockers and regear if the money comes in time NOT BLOODLY LIKELY
Clean the damn thing HALF DONE
Updated:
TORX said:
- Fix Idle Issue (DONE)
- Build rear bumper (DONE)
- Build track bar brace (DONE)
- Build steering box brace (DONE)
- Finish passenger half door (DONE)
- Have CB Tuned (DONE Thanks FiveNDime)
- Beef up the rear cargo tie-downs (DONE)
- Change transmission and transfer case fluid (DONE)
- Wash/Vacuum the Jeep (6/21)
- Have tires rotated/balanced (Next Week)
- Check fluids, torque suspension, grease joints, air pressure, etc (6/20)
- Teralow (Not going to happen)
- Install rear disc brakes (Not going to happen)
- Figure out how to fit 10lbs of junk in a 5lb bag :D
(becoming more of an issue each day)
Still to do
-Install CB radio/antennae
-Install 231 transfercase
-Fix TC skidplate bolt
-46re Tranny service with Gov-pres Sensor & solenoid
-Install Rear track bar bracket/spacers
-Install Dana 30 locker/Inner seals/Warn diff skid
-Install Rotors & pads
-Install front tow hooks
-4 wheel alignment
-Oil change
-Clean Inside/outside
-Re-up Membership
Should be able to check 75% that list off by monday morning
I still need to:
Adjust the shift linkage on my transfer case so I can get 4L
Replace the bent track bar
Wire up the front locker
Make a cocktail dispenser
Late to the party but...
- Install M4O front bumper (no winch ATM)
- Install JT Fab rear bumper
- Install steering box brace
Doesn't sound like much, but when you travel every week for work it'll be quite a time crunch.
Still need to:
-Finish rear tube bumper
-Paint front and rear bumpers
-Re-install winch and line
-Find new model electric fan and wire it up with Spal fan controller
-Change oil
-Torque suspension/grease zerks
Ball joint press?
