What do YOU need to do before NWFest 2010 ?
Lift
Tires
Front Bumper
Rear Bumper (currently in progress)
Winch
Roof Rack
Lights, lights, lights, lights, lights.
Sliders
Xfer drop
Stereo
Doorless mod(?)
Sleeping platform/interior storage mod(?)
Lockers and regear if the money comes in time
Clean the damn thing
Rear bumper and some lights done.
Kinda waiting to do the lift before I really dig into anything else so far
1. replace ball joints on passenger side (DONE!)
2. Swap in TJ Dual diaphragm booster and MC (parts acquired Starting tomorrow)
3. Put new rear drive shaft back together and get gunk out of slip section (in progress gunk out just need to reassemble)
4. Swap in SYE Xfer case
5. Retest everything
Last test run went well just getting to all the things I wasn't happy about. If I have time and funding I will go down to ACRO and have my beadlocks mounted. I will also swap in a ram 2500 brake MC if I have time.
Ordered Output seal for 46RE
Ordered input seal for np231
Ordered rotors/pads
Left to do:
Order Yukon spartan locker DONE
Order filter/Pan gasket for 46RE NOT HAPPENING
Purchase a Case of Atf+4 NOT HAPPENING
Install 231/seals/tranny service PRAYING THATS DONE THIS WEEK
Install Spartan locker/Axle tube seals
Should have this list checked off within 2 weeks.
Updated:
- Build track bar brace (DONE)
- Build steering box brace (DONE)
- Beef up the rear cargo tie-downs (DONE)
- Change transmission and transfer case fluid (DONE)
- Fix Idle Issue (This Weekend)
- Build Rear Bumper (In Progress)
- Wash and wax the Jeep (Week Of)
- Teralow (If time, funds, and fate allow)
- Finish passenger half door (After Bumper)
- Install rear disc brakes (Not going to happen)
- Figure out how to fit 10lbs of junk in a 5lb bag :D
-Install IRO OTK steering
-Buy/install bilstein shocks for the rear
-Possible weld the rear end (new carrier) or add friction plates
-Rocker replacements
-Replace a few gaskets and sensors that have been annoying me
-Reinforce D30 control arm mounting/replace UCA bushings
-Weld trackbar bracket onto the frame (keeps coming loose/popping)
-MAYBE add a hitch to the rear bumper if I have time
-Install gas tank skid
-Weld shackle relocation brackets up
-Change all fluids
With 3 days a week off, I'm hoping I'll be able to pound this all out in time to properly test everything before NWFest. But because nothing is particularly major, I'm not too worried.
~Scott
Well..... for me... see if am going or not that'll help haha...
But my list is:
1) Buy a long arm kit
2) Get it installed
3) get 33's to put under it " got my eyes on some"
and i think that'll be enough to try and accomplish haha. But if i have time.... try to make rocksliders
But my list is:
2) Get it installed
Also, Red Letters :)
He is still two years away from being able to go red.
Yeah that's what i figured. but it just depends on how long it's going to take me to get enough money to get the lift and tires haha
Honestly, I say come on out with your current setup.
Trying to do a long arm install and total suspension/tire overhaul before a big trip is asking for trouble. If your rig is mechanically sound, then make the trip out, run some trails, and see what others are running. You very well may change your mind by the end of the weekend.
alright yeah we'll see.But i mean i'm still not sure if im going or not haha and i'm looking for tires on craiglist that have decant tread
my throwout bearing started making alot of noise the other day:explosion... guess I need to do a clutch kit now:banghead:
Come with your stock rig! :wave:
I drove down just after my 17th b-day to NWfest two years ago when I received my first XJ as a birthday present. I brought it stock, but had a lift kit at home prior to NWFest (I was recommended to not install is and try to wheel in such a short time). I ended up hitching a ride with another guy there on the trails, had a blast and learned a lot more than I would have trying to drive my own rig with no real wheeling experience.
We've all heard the "Well I'm a good driver, and I've driven off-road before" thing, but once you get out there you may find your knowledge/experience is a bit lacking on the driving part (not saying that's what YOU are saying, but just giving an example). Nothing wrong with coming down for the weekend to see what XJs can do, and watch others abuse their rigs.
~Scott
