got board, found myself on a rti ramp. i know its not a jeep but whatever. index 300 :)
put a new cb in, still had 3+ swr on ch 1 and 40. went from a 3' to 4' tunable tip antenna, and that fixed the swr readings.....until i mounted the cb back behind the center console, then the readings went haywire again. guess ill have to find a new mounting location
Finally installed the rear driveline. Started it for the first time since October...felt good to drive it again. Swapped out the rear leafs for some newer ones.
Sent from my DROID2 GLOBAL using Tapatalk
I know it's not an XJ but it is a Jeep!
Got the front axle pulled from my YJ in preparation for the new one and SOA. Also got the shackles cut down since I won't need that 1 1/4 lift from them when I get done.
Dave
well i got alot done to project MJ today. so i turned my attn to my stuff around noon.
this is what i created the last time i worked on it...
a couple shots of the guards, with the lights installed. looks good. still mad, they creased the qutar pannels durring install. the fitament is less than premo.
MJ/XJ parts :patriot:
after i pulled the sliders off i realized just how much i have put this ole girl throo. :cry: my poor uni body...
Bronzewyrm on the second hill climb on the first section. That trails gotten torn up. :cool:
Caused the following...:tears:
She Looks Alot Cleener IMO now. if i dont roof slider it. im guna leave it flat toped till i pony up and hybrid cadge it. its amazing how close gray 2K primer is to sandstone met. lol
Bronze.
On my way home from work yesterday in heavy rain, my Jeep started sputtering then stalled. I coasted around a corner and parked it. Called a tow truck and got it home.
I took the day off work to change what I thought was the fuel pump. Last night I bought a pump, and fuel filter. but when I went out today and tested it it fired right up and ran without a problem. I played with the ballast resister and that didn't seem like the problem. Also when I turn the key on I can here the pump engage. So I just put in a new fuel filter and drove around a bit. No problems. I'm hoping that it was just the filter. I guess we'll see tomorrow when I go back to work.
Crank position sensor
Got the rear axle removed form project Cherokee slayer. Also ran into some money so I ordered new spicer ball joints,SYE kit and some misc. items from the jeep guy.
Dave
Doesn't matter tracks, tires or tits their all a problem!
Today I got up before noon
Made some breakfast
Then put a third crossbar on my roof rack.
I also put a new mass airflow sensor in the DD. Runs like a dream! (if your dream is a 2000 chevy prizm)
THIS POST BROUGHT TO YOU BY COMIC SANS
