Extinction
- Pennsylvania
So here's my issue. I was welding the driver side front leaf spring mount. Checked the floor area before and found it to be under the rear seat where no carpet or padding was. Well ended up a mouse had a nest up against the ssides didn't see. It caught fire and the wired all melted coming from the front going to the back, to the passenger side from there and to the fuel pump. When the fire happened I got it out and noticed the wires there. Not knowing if they were OK in the wrap I hooked the battery back up and turned the ignition on to check the blinkers. Those and the brake lights didn't work. I then found the wires to be pretty melted once ripping rhe seat and carpet up. Spend a few hours separating and replacing each wire there one by one. All wires soldered in. Hooked the battery up thinking everything will be good. Brakes worked. Fan turned on, no guages, no blinkers, no start. What could have happened here besides all the wires which I replaced?
