i knwo its monday night but what ever. i just put the new HD leaves in old blue and im impressed at how high it takes the ass up. now spacers for the nose are orderd and the "not lifting" of my DD has begun lol
What kind of HD leaves did you get? Mine aren't looking too healthy, and will need replacing soon.
We removed 1 front and 2 rear axles....installed all of one rear, and partial one front axle, as well as one rear bumper (JCR). Oh, cleaned out some rodent pee and poo from my intake manifold, and evicted 4 new born somethings....oh, and don't forget the doughnut taste test....yummy:viking:
It was a full weekend. The back is just a little sore/stiff today.:sunshine:
removed old tie rod, setting the new HD one to the correct length with new tre's. axle shafts are also out. will be replacing the u-joints hopefully tomorrow. got the rear seat back in for the golden mtn trip
I:
and then I:
and:
All night catfishing, then tailgating and the Kenny Chesney concert. Anybody have a new liver?
i broke both my rear bump stops trying to unbolt them to replace with better ones, so instead of just welding them to the frame or drilling them out tapping the hole and rethreading the nuts in the factory position i got a 2" piece of square tubing, drilled some holes welded the nuts to the inside of the square tubing, then tack welded the square tubing to the frame and bolted the bump stops to my new mounts that are now 2 inches lower, =) i no longer rub at full flex so thats a plus right?
went road tripping this past weekend...
left chattanooga, went through knoxville; visited Matt & Tony at the Tint shop... went though NC to get to Spartanburg SC, where i visited my friend Brian for his 21st birthday, and chillaxed a bit. then headed down to atlanta to see Tim and Rebecca... rocked out a bit on the 360 with them and tyler... then tyler and i headed back home to chattanooga...
definetly stayed busy!
come to Golden Mountain next weekend to see what I got!
DO COME!!! worth seeing for sure :confused1
and it's my birthday! :shocked:
Well since my weekend was a complete loss to the flu I'm having to make up ground in the evenings to get ready for this weekend. Tonight I: installed oil pressure sensor, engine temp sensor, replaced oil filter adapter o-ring, oil change, fixed transfer case leak, topped off front axle fluid, replaced seal on rear diff cover, new fluid in rear axle, replaced all four stock shocks with procomps, and installed swaybar with quick disconnects. Tomorrow night I hope to get the speedo working, fix brake vacuum problem, install mirrors, install speakers, clean up, remove front window tint, load up jeep, pick up my spare tire, and lord willing trim the fenders.
LOL. Stupid garages. I hate you.
Soon I need to do RMS, FMS, VC, get my booster rebuilt with a new pushrod and install a new wheel cylinder.
