stumpXJ
- Atlanta, Georgia
Got my free Generator rebuilt and running like a champ.
The place I used to work was throwing it out because the engine 'locked up'. So I snagged it to see what was wrong with it since it was otherwise just fine.
I tore it apart about 6 months ago only to find out that the carburetor butterfly and screws had come loose and went into the intake. The butterfly itself held the intake valve open and cause it stop running, while the screws made their way into the combustion chamber and stop the piston from moving/pull cranking. I knew something wasnt quite right since the oil level was good, there were no holes in the block etc... Managed to straighten out the buttefly, found two more screws, and rebuilt the carb. The valve was not bent surprisingly....Meanwhile, I spent 13 bucks on a head gasket and spark plug, rebuilt the engine finally yesterday, and she fired up and purred on the first pull of the chord.
So, I basically have a $600 generator that runs perfect, for $13 bucks and a little time. Its a 5250 watt Porter Cable genny, so it will come in handy for the next hurricane/storm season. Just need to make up a disconnect box for tying into the main panel on my house. Yay!
~ Stump
~ Stump
