jcnoble
- Huntsville, AL
I was thinking of going HD mount untill i saw the bulletproof trackbar. The only thing with that is its not adjustable. You send the measurements and they make it for you.
jcnoble said:I was thinking of going HD mount untill i saw the bulletproof trackbar. The only thing with that is its not adjustable. You send the measurements and they make it for you.
jcnoble said:Caster is 6.5 degrees, tre's are tight, ball joints tight, bearings tight. Track bar tight. I haven't messed with the tires lately, but I only get dw after hitting a big bump or hole. If tires werent balanced wouldnt i get wobble without pothole inducement? Oh, and yes , I have been investigating dw for quite some time I am just getting around to fixing it. Had to get rid of ball and chain.
