Viair 450C air compressor with pressure switch.
tcharon
Lake Tahoe, NV
450C is a continuous duty cycle compressor. Maximum Performance Air Compressor features a 100% duty cycle and is designed to be hard mounted to your vehicle. Sealed compressor motor keeps out moisture & dirt, and is thermally protected. Comes with 1/4” x 18" braided stainless leader hose and mounting hardware with in line check valve and insulated wiring for simple installation. 12-VOLT Designed to be used with an air supply tank. Permanent Magnetic Motor Sealed design - Moisture & Dust Resistant Oil-less Design High Performance PTFE Piston Ring Stainless Steel Valves Gearless Direct Drive Motor Anodized Aluminum Alloy Cylinder Automatic Reset Thermal Overload Protector. Airs up a 35" tire from 15 to 30 psi in less than 3 minutes. Maximum working pressure is 150 psi. Oil-less operation, air filter cartridge, and 23 amp/12 volt motor. Permanent Magnetic Motor Permanent Magnetic Motor Duty Cycle: 100% @ 100 PSI. Amp Draw: 19 Amps Dimensions: 12.75” L x 4” W x 7” H Net Weight: 9.75 lbs. Includes mounting hardware (nuts, bolts, locking washers) Pressure switch is on at 110 psi & off at 150 psi. Retails for $300 w/ pressure switch. Works perfect, barely used, fair price $170 for all. You choose shipper, check on cost, pay me for shipping & I will take to your shipper or pick up for free in Fernie. Or I can bring it to Fall Fling & meet you 10/1 or 10/10 on I-15 or Hwy-6 to Moab. Tom 250-423-7722 or Skype- thom.charon.
