im planning on putting a detroit truetrac in the d30 of my 88xj with the vac. disconnect. i read this on off-road.com...
"...Another problem is that since only one axle is ever disconnected, an automatic locker or limited slip differential can cause problems with the axle and with handling. The drivers side axle is always spinning the differential.
The TJ has done away with with the system completely which is good in that it is not likely to fail, but since there is no way to stop the differential from spinning, an automatic locker or limited slimp can degrade handling on the road."
I managed to get a fullsize pass. side shaft from an xj d30 when walking through a boneyard. can i just slap it in and get a blockoff plate for it?? And would this setup be any better(or worse) for handling than just the drivers side rotating? im thinking the limited slip with screw with my steering around turns but im a little lost as to what i should do to keep good handling and limited slip up front without spending lots of $.
Any help would be much appreciated!!
