Suggestion if you are thinking v8 swap:
408 Mopar (based on the 360 Mag motor, take it .030 over and stick a 4.00 stroke crank.) Back it with a 46RH (A518 if you want OD) or 727 and tc of choice. Use the electronics from a 92-93 Ram/Dakota and keep the EFI. Loads of torque on pump gas and very reliable. For more info check out:
www.krcperformance.com or click here:
KRC Longblock Info scroll about half way down.
Here are the specs on their RV 408
Crankshaft Mopar Performance 4.00" cast
Camshaft Mopar R/T camshaft
Harmonic damper Mopar Performance
Heads 1.92 non ported R/T heads
Manifold M-1 2bbl Manifold
Pistons Ross 8.0 or 12.5 compression forged pistons
Connecting rods Forged Magnum
Timing chain Comp Cams double roller
Roller Rockers Comp Cams 1.6 aluminum
Lifters Mopar Performance
Pushrods Smith Brothers 0.083 heat treated
Oil Pump Melling High Volume
Oil Pan R/T Oil pan with pickup
Valve Covers Mopar Performance Black wrinkle
Head studs ARP
If you wanted even more torque dump the M1 2bbl for the stock intake with aluminum belly pan.
eace:
Travis
