Tires rubbing.
87m6chris
Canada
Just put a nice set of Michelin A/T 31's on the 95 XJ, they look great but the lugs on the inner side are rubbing the lower suspension arms when turning tightly in either direction.
Is there some way of correcting this or do I just have to live with it?
Thanks,
Chris
Buy rims with less than 5.25" offset or adjust the steering stops on the axle housing.
For a cheaper solution, just wait a little while. I have the same problem, but i got a feel for it and now i know just how far i can go before they rub. Once you get used to it, it probably won't bother you as much. Just my $.02
