Things to do
To Do:
1. Finish TNT LAs.
2. Install TNT trackbar.
3. Install front Aussie locker.
4. Fill CO2 tank.
5. Install SOLID diff cover on the 8.8.
Want to do:
Convince Pat to whip up another roof slider for me :D
TellicoReadyXJ said:
Want to do:
I think it's to late for that.:moon: JIM.
XJ&TJ4ME said:
I could have probably got a fat one for ya!!! Ya didnt ask!?!
Nah in that case I'll pass I s'pose :D.
Buy an XJ?
Rev Den said:
Make hotel reservation....
hang on a min....
Done.
Rev
Gonna be a "shower with Rev" ticket in this year's raffle?
My list is pretty short;
1. Build long arm front suspension
2. Buy tires (33")
3. Lock the 8.25
4. Build roof rack
5. Finish rear bumper to fill in the cut quarters
6. TJ flares
7. etc., etc.
Ok, maybe it's not so short. I should at least have tires by then!
try to get this thing done by then (too long of a list to post)....otherwise, I will be wheeling my 2000. at least I have a 'plan B' ;)
Put me down for 5 tickets.
This week I finished:
Front frame plating with 1/4" plate.
front shackle mounts finished.
all four spring plates 1/2 inch plate
shock mounts added to the d44
Rear frame plated at shackle mount.
Rear frame length shortened to 4 inches behind shackles
Shackle mounts 1/4" plate
shock mounts added to the d60
So here we go:
Seats
gauges
harnesses
roll cage
rebuild factory front bumper mounts using 3/8 plate
cut out entire floor pan and build custom floor from back wall to the firewall
brake booster and master cylinder for rear discs (got it)
locate hydraulic slave cylinder mounts for sm465 4spd transmission
mount all brake lines
front brake hoses
rear center hose
fuel cell install (got it)
drag link
tie rod
hydro assist
spool rear d60 probably do axle shafts, hate to spool without disired shafts
front locker of some kind.
install advance adapter small block motor mounts (got it)
install Tune Port Injected 350 (got it)
install Transmission and t case (got them)
install the Painless Wiring harness (got it)
find proper manifolds or shorty headers
y pipe and exhaust system with oxygen sensor
build cross member
traction bar
build square driveshafts unless i somehow find money for shafts
build flat bed
rocker replacement with possbily plate or box tube
one or two batteries
radiator hoses
cooling fan(s)
about 22 more lug nuts
shocks all the around
rear limiting straps to avoid breaking leaf springs
wrangler leaves with the proper amount of lift after the powertrain is in (currently stock)
pretty sure there is more but oh well. i've spent about 15 hours a week for the last two weeks and will probably continue to do at least that until its finished. Working again in a fab shop is such a great thing.
finally going to wheel again. Last event for the MJ was Winterfest 03.
Gene MJ
To Do:
1. Finish TNT LAs.
4. Fill CO2 tank.
Want to do:
#3 is done.
JIM.
w_howey said:
1. Lower Control arms
2. Front tow points/winch bumper
2a. Repair winch contol box
3. Install EZ-Locker
4. Get the heater working
5. Put the doors on
6. make sure tow rig will make it
7. find cap/camper for tow rig
8. Other things I'm currently forgetting
4. Heaters works :rof:
8. Replace the trashed front U-joint
ILLXJ said:
#3 is done.
JIM.
YOU DA MAN! The 2 quarts of gear oil in my truck caught my eye this morning and I kicked myself for not leaving them in the Jeep.
Still using that HP camera, eh?
No worries.
I left a big ol' 3 gal. jug at Jim's.
Hale
supprisingly my Jeep survived the year pretty good so i've got a pretty short list this winter.
1) order new driveshaft
2) change fluids
3) general check
4) traction bar if i can find the money
5) wash the years mud off
6) wait until WF
XJ_ranger said:
1) Learn how to drink an Irish Car Bomb the right way.
I think thats it... :fuse:
Is there a wrong way?
Depends on which jeep I will be bringing. The woody needs a few things and so does the black beast.
List for the woody:
MPI swap
new tranny and tranfer case
weld up the 8.8
front tow points installed
t/c skid plate(no more holes in the t/c)
install a radio that works
install 4.5" springs with spacer
install new control arms
install shackles out back
I'm sure there is more. If I bring the 96 the list is not so long.
Kim
Those are mighty tasty, how the hell did you screw it up.
hmmm
lift needs to be installed
wheels need to be installed
winch bumper needs to be installed
winch needs to be installed
OBA needs to be installed
SYE needs to be bought and installed
sliders needs to be bought and installed
front locker needs to be bought and installed
thats it not bad
And i thought you were supposed to run from them :D
