Things to do
Thanks to Jim, #1 on my list is closer to completion:
I can't thank him enough :D
We'll figure something out.:gag: JIM.
Ramsey said:
Those are mighty tasty, how the hell did you screw it up.
I didnt understand the 'drop it in' was literal... and poured the cream and whiskey into the guiness... :tear:
But I was too drunk to notice the difference after 1 kamakazie, 1 tequilla shooter, 2 black superman's and 1 mind eraser...
You poured it in huh, silly newbie.
Things to do:
1) TnT Customs Longarms
2) TnT Customs Trac Bar
3) TnT Customs OTK Steering
4) TnT Customs UBEs
5) Rock Krawler 6.5" Coils
6) Swap in Ford 8.8" w/ discs
7) Swap in HP D30 w/ TnT Customs Truss (95 cherokee)
8) 35" Maxxis Bighorns
9) 4.88s
10) OX Lockers front and rear
11) Front and Rear (tire carrier rear) bumpers from AJ
long expensive list, but the first 7 will be done by thanksgiving hopefully
Gene MJ said:
Front frame plating with 1/4" plate..........:clap:
front shackle mounts finished.........:clap:
all four spring plates 1/2 inch plate.......:clap:
shock mounts added to the d44........:clap:
Rear frame plated at shackle mount..........:clap:
Rear frame length shortened to 4 inches behind shackles........:clap:
Shackle mounts 1/4" plate.......:clap:
shock mounts added to the d60........:clap:
Seats
gauges
harnesses
roll cage
rebuild factory front bumper mounts using 3/8 plate..........FINISHED:clap:
cut out entire floor pan and build custom floor from back wall to the firewall
brake booster and master cylinder for rear discs (got it)
locate hydraulic slave cylinder mounts for sm465 4spd transmission
mount all brake lines
front brake hoses
rear center hose
fuel cell install (got it)
drag link
tie rod
hydro assist
spool rear d60 probably do axle shafts, hate to spool without disired shafts
front locker of some kind.
install advance adapter small block motor mounts (got it)
install Tune Port Injected 350 (got it)
install Transmission and t case (got them)
install the Painless Wiring harness (got it)
find proper manifolds or shorty headers
y pipe and exhaust system with oxygen sensor
build cross member
traction bar
build square driveshafts unless i somehow find money for shafts
build flat bed
rocker replacement with possbily plate or box tube
one or two batteries
radiator hoses
cooling fan(s)
about 22 more lug nuts
shocks all the around and mounts.............FINISHED:clap:
rear limiting straps to avoid breaking leaf springs
wrangler leaves with the proper amount of lift after the powertrain is in (currently stock)
got a lot done this last week, figured I would start putting the happy smiley next to things that are finished. also going to have to switch from two to three nights a week to get this thing done.
hurry...
mac 'started the front frame conversion tonight' gyvr
my steering gear has got to be shot... ...well i have a horrible leak and have just been 'topping her off' all summer.
but even when topped off these days, it whines like a mother.
so i guess its either my pump or the gear.
i want to upgrade 'dakota-style.'
that is my goal for before winterfest.
i havent picked anything up yet.
might as well get new lines for the pump, etc, eh?
any suggestions?
words of wisdom.
whatever?
Heh, I doubt it. Of course, if you have successfully removed your transmission crossmember without bolt breakage, then yours would be 10x easier than mine.
I fully expected to let my XJ sit outside Jim's shop until I came back to finish her up, but next thing I know he PMed me progress pics. What a guy!
IntrepidXJ said:
hey Jim......want to do another? Not because I can't myself....just because I'm lazy :looney:
:wave:
The next one I do I'll have to charge more than the kit cost.:looney: JIM.
ILLXJ said:
Need to do:
Install new tie rod- it's on the way
Install rear disc brakes
Install new spring kit in the No-Slip
Want to do:
Get a winch & new tires
JIM.
I have to add install header & new intake. Also remove new tires from the list, I have a feeling the TrXus are gonna last alot longer than I thought. JIM.
well, the wife's XJ is on it's way.
I've got most of the body work done, so I can start on the rocker replacements soon.
It runs right, got the 4wd actuator fixed.
gotta do maintenance crap like u-joints.
Gotta budget boost this thing with new leaf packs.
install hale's bumper in the parking lot.
Haleyes said:
I'd like to get a box similar to what the MWC Brewmister has in the cargo area. I still need to find a Co2 regulator. Need to get my powersteering issues lined out too.
Hale
I need to install the 99+ intake I got from Byron.
Still haven't got the power steering figured out yet. I'm about to give up on it.........fuggin' thing.:bawl: I'd like to have my rock lights and new front bumper on too.
Hale
Any night wheeling go down at winterfest? Or is it just too damn cold.
Anything is possible.
However, our night run at Flat Nasty didn't turn out so well.
I've had these lights for a while now, I'd just like to get them out of my way.
Hale
What is the weather like up there usually.
