Buggy not going to make it to winterfest again...however I will still be wheelin a rig...
The baby jeep will be making its first appearence off road at the badlands. Should be fun. Running 31 tsls, detroit locker rear, detroit tru trac front, jks discos, the old buggy jeep winch on a multimount, gas tank skid plate, custom air intake setup, optima and many more leftover parts from over the years...
only thing left is grooving the tsls, swapping some rims, and maybe a fabbed up tcase skid plate...
Originally Posted by XJ&TJ4ME 1. Build new rear bumper w/ tank skid incorporated into it Still working on it
2. Tie in front bumper a bit more or maybe build a new one Done(built a new one)
3. Finish sliders Done
4. Lock the turdy on its way 5. Reserve an oriental hooker Done (multiple times )
also installed JCR's 1 ton steering, new RC control arm drop brackets,PORC's SYE kit and DS, new air intake and a few other odd ball things.
I guess I should start checkin out my trailer to make sure everything is up to snuff on it......
1 fix ram assist and steering gear will be fully hydro
2 remove doors yup
3 maybe boatside a bit not gonna worry about it, she sits pretty high as is
4 add some to the cage will happen
5 install seats kinda has to happen now
6 maybe find a front 60, and bigger tires. check
1. Lower Control arms *Done Finally*
2. Front tow points/winch bumper
2a. Repair winch contol box *wife told me to buy a new winch*
3. Install EZ-Locker
4. Get the heater working *Done*
5. Put the doors on *Done*
6. make sure tow rig will make it
7. find cap/camper for tow rig *staying at the Inn*
8. Other things I'm currently forgetting
8. Replace the trashed front U-joint *Done*
8. Work on cargo area. (figure out way to stuff all the stuff in there)
8. Where to put the spare. *Ratchet straps*
what is the prefered spot for the flag at the bad lands front or rear. I would like to put on the back just so I dont have to look at it all day. just want to fallow the rules.
Doesn't matter, it is just supposed to be 2' taller than your rig. I used to zip-tie mine to the radio antenna and nobody ever said anything, so I would imagine as long as you have one you should be fine.
well i found out my knee surgery is getting delayed so i'm on for sure. not much of anything to get done on the jeep, truck, or trailer. guess just get the jeep packed and strapped onto the trailer.
Yep, it fit into place just like it should have the first time :dunce: I didn't even have to re-adjust my t'case linkage. The Heep rode like a dream on the way back home with the new trackbar too.
And my heep has developed some serious front end problems including a non-death wobble type wobble that sometimes turns into death wobble, and sticky calipers.
1. replace motor mounts - :guitar:
2. synthetic winch rope - :guitar:
3. new seats and harnesses
4. cage work for #3 and some other pieces
5. raise rear shock mounts
6. new rear shocks
7. rocker replacement
8. plate frame rails
9. new crossmember/skid?
10. clear spot to work on jeep... - :guitar:
