vetteboy
- morganville, nj
vintagespeed said:I can't say whether this is true or not. I do know that the spindles & knuckles on a 3/4T D44 are much larger than the 1/2T stuff.
Well, FWIW (and one of those mysteries of axle hardware), the 8-lug spindle from a Chevy 3/4T D44 bolts right in place of the 6-lug spindle from a J-truck D44, without having to swap the knuckle out. However the Ford one going from 5-lug to 8-lug gains another stud for the spindle so obviously that doesn't work.
88rockxj said:i herd the 5 lug external locking hubs flex more then the 8 lug which is inside the rotor causing more breakage?
Are you sure you mean external locking hubs? Any of the Warn style you'll typically see (and the Ford automatics that they usually replace) are all internal. External ones are stupid and are the main reason why my Dodge 60 has drive flanges, because the external hubs are mad weak yo.
