The Stupidist Jeep on the Planet
decided to do shackle relocation, a friend had some pieces he made up but nevery used em, so i used em as i needed, everything is .25 plate, i also plated the old shackle boxes and plug welded it just for kicks. big reason for doing the relocation is i has limited down travel, like 2-3" and inverted shackles was garenteed, now i can easily max out the 12" shocks, also picked up some .75" rustys shackles from the NAC classifieds
hoping this week to pick up the steel to finish up rear floors aswell as get fuel cell mount welded in and get pieces to install the exhaust
changed plans for the exhaust, instead of the stupid 3" muffler and tail pipes i backed things down to 2.5" and also used a cherry bomb turbo that fairly compact its somthing like 7"x13" had one on my last jeep and it sounded good
plan this evening is to go pick up sheetmetal to finish up floors tomorow
rear floors are done(minus bedlining and welding in fuel cell mount) there also all seam sealed(not pictured)
rear floor is hurculined and fuel cell mount is in, still gotta weld on the straps but that will come at a later time. Also opened up the holes for the shocks a bit to be safe. Plan tomorow is to have it move under its own power
damn, I missed the break-in run.
Psh why do you need me to help move that turd across town?! Looks like its driving just fine! :D
Axles are finally geared
Front 5.38 gears, Lockrite Locker
Rear Axle 5.38 gears Full Spool
axles should be put back together for the final time this week and bolted under the jeep for the final time, also ordered everything for my fuel system just got one fitting on backorder but i should beable to plumb it all
not to be outdone by ross with box colecting ive been getting alot of goodies, got almost everything for the fuel system(waiting on the 3/8 fuel line quick conect)
Make sure you put 500 road miles on it first.
And don't fill it will gear lube, save the money and weight.
no you got it wrong, you drive it for 20 mins then you let it cool down for 20 mins, then you mash rev limiter up massive rock ledge
wrong again, if you don't spin tire right away, the gears will never seat correctly.
picked up a set of RJS 5pt harnesses, just using the lap belts at the moment till the jeep gets a full cage, the mounted with some pieces of plate i had laying around to the rocker legs and floor subframe
also got a rollover vent for the cell and installed that, hoping to get frt stiffners on tomorow and the frt axle assembled and in, then over the week get the fuel system in, but things never seem to go as planned, o well
frt 60 is in for the final time, had to grind down the 10 factory shafts like colin, drivers side is tight here and there but the more i turn it the looser it gets, just gotta tighten up some bolts and fab up some coil retainers and ill be done with it
tomorow i hopes to get the fuel system sorted out
