mntllycrzy
- south jersey
ok so i checked the manifold bolts. all are tight. i unplugged the 02 sensor, same problem. my xj has the extra plug for the second connector so i didn't know if i should plug it in. i plugged in the flat 3 wire job. i understand what the other connector is for. so basically i'm still in the same place. i had a perfectly normal, good running truck, then i cleaned the tb and it is going crazy
