mntllycrzy
- south jersey
does anyone have a wiring schematic for this circuit???
is the tps supposed to be set at .83 or .2? is it the same for auto and manual?
The ECU side of the TPS (manual or automatic), (87-90 years) should read 0.83 V at idle, ignition switch power on, engine off.
so it is the same for manual and automatic? and i still check between B and C?
so now that i'm totally stumped do i take it to a dealer?
so it's taken me two days of reading this thread and fartin around with the heep. I've checked, cleaned, and tightened the ground on the block, and on the firewall. I have set my tps at .83v. i have checked and replaced vaccum lines, i have checked and tightened manifold bolts. the throttle body was removed and cleaned, and the problem still persists. when i start it up, the heep idles perfect right around 700-750. once i start driving the idle sticks up at 1500-2000 rpm. this actually all started when the throttle body was removed and cleaned and reinstalled. so at this point i'm pulling my hair out and i'm stressed out over it so any help would be great. I'm pretty sure that for some reason the iac is not closing. the iac was removed, cleaned, and reinstalled. i even tried swapping it out with another jeep. i tried disconnecting the battery and leaving it disconnected. when i take the air tube off of the throttle body and the engine is running, if i put my thumb over the hole that the iac sucks air thru it idles down to about normal. so i'm pretty sure something is telling it to stay open. any thoughts?
by the way, this is an 88 4.0 with m/t. it's a 4dr laredo.
thanks in advance
i've had the tb off three or four times since the initial cleaning. i have replaced the new tb gasket with another new tb gasket. the vac port on the side of the tb is plugged in, i didn't remove it from the map sensor so it shouldn't be wrong. the only throttle linkage i disconnected was at the arm on the tb itself and there's only one way for it to go on. the problem definitely increases with temp i'm thinking. on cold start up it barely runs, then once it is warm it idles up to 2k. if i try another tps, one from an automatic, what happens if i plug in both connectors?
i have an automatic tps, do i plug in both sensors?
