Wednesday I could see light at the end of the tunnel. It was final assembly day.
Started by chopping my u-bolts down to length. I can't stand when you can't get a socket on u-bolt.
Took a cut off wheel, and chopped them down. Little bit of file work, and I had the thread cleaned up.
Installed the brake lines, and Dakota line. Even with my offset mount location, there's still plenty of slack in the Dakota line.
Something just says beef with the 8.8 drive shaft flange when compared to Dana's strap style yokes.
8.8... Done.
Next task was filling the diffs. I always ran 85-140 in my old axles. It seemed to quiet the noise form the lockers.
Got the brakes bleed. Used about a 1/2qt of fluid. Installed the old 30's for the test drive. Did a quick tape measure alignment. I take a tape measure and hold it on one tire's sidewall, and measure to the other sidewall (same place, same height). Then take another measurement off the back of the tire at the same height. I've found 1/8" of toe-in to work well. In this case the front measured 45.625, and the back measured 45.75.
When installing the rear tires, I noticed my soft lines were resting on the rim (always a concern in the back of my head). FAIL. I cranked out an aluminum spacer as a temporary fix. I'll probably end up redoing the hard lines later.
I'm in love with the stance on 30's. Seems perfect. All you LCOG guys are probably shacking your head.
Keep in mind the springs are brand new. It's going to settle a bit in time.
At this point I started it up. I prepared myself to deal with the known upcoming issues. Loose bolts, no brakes, binding steering. Stuff that usually goes along with a complete suspension overhaul.
Put it in reverse, and heard a clunk... Detroit... I smiled.![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Brakes felt... different. I wouldn't say spongy, just different. I think it's the rear discs. They feel a lot like Jeepforceone's when I converted to discs. I can almost lock up the tires so I have brakes.
It drove insanely well. Tons of power with 4.56's and 30's. It was suppose to be an easy .25 mile test drive, but I was cranking through the gears.
The Detroit isn't bad at all compared to my old Aussie. Pretty quiet, and just clunks around when putting it in gear.
I hit a few speed bumps at 20mph. I was expecting all sorts of clunking from forgotten suspension bolt final torques, instead all I got was silence. The suspension seemed to work really well. Even with no sway bar it was very stable. Seemed to wander a bit, I think it's a caster issue. Then again my steering wheel was way off.
Still had a bit of snow remaining, so I grabbed 4hi on the fly. It's so nice to have four tire fire again! It just powered through it.
Overall, my mind was blow from the test drive. A solid three days of wrenching, and it worked.
Only issue to fix after returning was centering the steering wheel. Anytime you change your lift height, you toe-in and steering wheel will need to be adjusted.
Loosen the two 15mm bolts on the drag link adjuster sleeve, and rotate it to center the steering wheel.
I'm heading out in a few for the initial gear break in drive. A short 15-20 drive of various speeds, and then let the diffs cool off. We'll see if any other issues arise...
![P1070113.jpg](/proxy.php?image=http%3A%2F%2Fi159.photobucket.com%2Falbums%2Ft123%2FTorx_89%2FNail%2520Salon%2FP1070113.jpg&hash=fe0dc026fc94b6f6fbd7e8faa8665a5c)
![P1070115.jpg](/proxy.php?image=http%3A%2F%2Fi159.photobucket.com%2Falbums%2Ft123%2FTorx_89%2FNail%2520Salon%2FP1070115.jpg&hash=c528c3fbce48d4f0a8250596ea8674fc)
![P1070117.jpg](/proxy.php?image=http%3A%2F%2Fi159.photobucket.com%2Falbums%2Ft123%2FTorx_89%2FNail%2520Salon%2FP1070117.jpg&hash=b50bfb3e9e14e0fde7b1e6bead35719a)
![P1070118.jpg](/proxy.php?image=http%3A%2F%2Fi159.photobucket.com%2Falbums%2Ft123%2FTorx_89%2FNail%2520Salon%2FP1070118.jpg&hash=57d0c341e4b1b5cb87bfdc04b721a232)
8.8... Done.
![P1070119.jpg](/proxy.php?image=http%3A%2F%2Fi159.photobucket.com%2Falbums%2Ft123%2FTorx_89%2FNail%2520Salon%2FP1070119.jpg&hash=bd5f78170636dd00c60559907e211d2e)
![P1070125.jpg](/proxy.php?image=http%3A%2F%2Fi159.photobucket.com%2Falbums%2Ft123%2FTorx_89%2FNail%2520Salon%2FP1070125.jpg&hash=7537d55d90123e3c39afd0b9f774ef1c)
![P1070137.jpg](/proxy.php?image=http%3A%2F%2Fi159.photobucket.com%2Falbums%2Ft123%2FTorx_89%2FNail%2520Salon%2FP1070137.jpg&hash=7d1f0b088c0da8bd08963f9f1fe6e800)
![P1070130.jpg](/proxy.php?image=http%3A%2F%2Fi159.photobucket.com%2Falbums%2Ft123%2FTorx_89%2FNail%2520Salon%2FP1070130.jpg&hash=6e1f79cb46c1ff34b50f2ce185b0350e)
![P1070139.jpg](/proxy.php?image=http%3A%2F%2Fi159.photobucket.com%2Falbums%2Ft123%2FTorx_89%2FNail%2520Salon%2FP1070139.jpg&hash=5b3016c24cc44275accfbc92e4393731)
![P1070129.jpg](/proxy.php?image=http%3A%2F%2Fi159.photobucket.com%2Falbums%2Ft123%2FTorx_89%2FNail%2520Salon%2FP1070129.jpg&hash=e68964969006e47c414727f3327cd833)
![P1070132.jpg](/proxy.php?image=http%3A%2F%2Fi159.photobucket.com%2Falbums%2Ft123%2FTorx_89%2FNail%2520Salon%2FP1070132.jpg&hash=42d7edd8e8affcbaf8b11245297e60ef)
![P1070133.jpg](/proxy.php?image=http%3A%2F%2Fi159.photobucket.com%2Falbums%2Ft123%2FTorx_89%2FNail%2520Salon%2FP1070133.jpg&hash=fb5858b0a50e083a91f1bd7b3348546f)
