THe NAC Lots-O-BFG KO2 Thread
Thought it was the master cylinder that was gone in my truck but I pulled it into the garage to double check.
All three lines coming from the ABS pump were ready to disintegrate. One of them had a pinhole in it that luckily didn't blow out.
Bought a roll of nickel copper stuff and did those three, the two from the master to the prop, and the one crossing under the motor to the pass side. Gonna go pick up front hoses as well since I'm already bleeding a bunch of air out.
Something is hanging up in the liner of my MIG gun, and it's feeding at such intermittent speeds it's impossible to even tack weld anything. ****ing annoying.
Really would rather be building a truck right now than ripping apart my welder.
Check the rear lines to, espedially where it goes between the fuel tank and frame
I just blow it out with air, it usually works.
So I never got to see Red Bull Frozen Rush, spent the day in the ER instead.
That one had already been changed by the previous owner luckily.
Did they tie the clutch slave line back up or did it rub through on the driveshaft like someone elses? :smsoap:
I'm not sure who is more fragile, Pat or you. You Ok?
My XJ has a 4.0 and ax-15 now - thanks for the help Adam. Going to continue putting it back together today.
Not sure. A few weeks probably. I still have to get a PCM and wiring harness.
Are your plug wires on in the wrong pattern?
You probably had the thing advanced by 1 tooth, that's how long it should've taken.
Reminds me of that beemer-whateverthe****hisnamewas guy who used to post in OEM tech all the time about how hard XJs are to work on. :D
THe NAC Lots-O-Post Thread
Yea, off by a tooth... Whatever it's done lol. I flushed my heater core and have heat and then found this
So no jumping til I add some more tube
Ya, for the most part. Left arm will be pretty useless for a while.
Saw that on the facebooks. Glad you're ok Mark!
Thanks dude. Ya I could have been much much worse and I was in good spirits after it. Thankfully I had a helmet on.
Finally got to ride in an ambulance though!
