vetteboy
- morganville, nj
I'm startin to like this AMC Eagle thing.
XJ rear axles are nearly a direct bolt-in, just gotta relocate one shock mount. A 4.0 is pretty much a physical bolt-in and even has mounting bosses for the front diff. A 242 transfer case will swap right on, and you can use the rear half of the stock 119 case to keep the fixed yoke.
I think it'd be pretty badass to get an SX/4 and drop my stroker into it with an AX15 or something, 242 case, and D44 rear.
