MoparManiac
- Amherst, NH
I'm starting to think Mark has never ACTUALLY had sex before.
1. Where should I mount my gauges when I built my dash/console. I've seen some guys mount them in the middle, others mount them like the factory directly in front of them. I'm leaning towards the middle.
2. I spoke with a vendor at Carlisle last year about clutchs/pp/flywheels about my setup (440, 11/12" flywheel, 400-500 HP). He suggested some kind of mix match of crap. I'm thinking about just getting a kevlar clutch and calling it good. My father and his friends always just went to parts stores and got stock replacement clutchs.
3. How well do you think an NP435 will hold up to 4-500 HP. I've read guys doing truck pulls with them and not having problems.
4. Trying to think of how to avoid lowering my crossmember/redoing my links. Probably just going to have to redo it all anyway.
5. Write out a simple process for how to bend tube, especially in multiple planes. I can handle simple bends just fine I'm sure.
6. How does 2" downpipes to a 3" exhaust sound for 4-500 HP?
7. Any ideas on a fan setup? I might just try a taurus fan and build a shroud for it.
I'd keep the tach/speedo in relatively stock locations. The rest of the gauges can go wherever.
If you're going to have them out of your line of sight, at least arrange them so you can get the most information in the quickest amount of time. Oriented so all needles pointing up is 'normal', etc. Nothing sucks more than seeing something might be wrong, then having to look back again to figure out what it is. Especially looking over and down.
I'm gonna try and keep mine in line-of-sight, at least the critical ones. In my case I'll probably want water temp, oil temp, and oil pressure immediately at hand, with voltage, tach, speed, etc in a secondary location. Probably idiot lights as backup for the critical ones if I can do it easily.
(yes, oil pressure *and* temperature; that's one of the more sensitive issues with the motor I'll be running. It'll likely need an oil cooler as well.)
I liked the Kevlar one in my XJ; it never slipped at all with the stroker and had a really nice engagement. Having a grabby badass clutch sucks for slow wheeling; I'd probably be willing to sacrifice some holding capacity or disc life for something with a less extreme takeup.
I think the weak point tends to be the tailhousing adapter and the output shaft, IIRC.
What happened to the 4500?
Cool story brah.
The biggest thing is just finding a way to mark it that makes sense to you. Second biggest thing is knowing which end of the tube to start from and/or what order you wanna do your bends in.
Start here:
http://pirate4x4.com/tech/bendin_tube/
For multiple planes, I've never had a situation where I've been able to measure the rotation angle beforehand. Like everything else you've seen me do with tube fab, I don't have a fancy scientific method for it. I just sight down the length of the tube with my eyeball and make a line parallel with the tube, so that when I load the tube in the bender, I want that line on top. This usually involves holding a scrap piece of tube or a ruler or something to represent the next plane, and then contorting yourself around the existing piece of tube mocked up on the vehicle until you find a way to mark it that makes sense. Sometimes it's easier to mark it 90* off and then transfer the mark before you put it in the bender, depends on the layout.
That's a tough visual to describe, did that make sense?
I also have some little scrap pieces of tube that I've cut into quarter-rounds and half-rounds that are useful for transferring marks 90* and 180* around.
Wait til you have to mark notches, that's even more fun.
Just keep a pile of 1.5" OD DOM scraps handy so you can cut/sleeve/rotate when you XXXX up a bend.
Single 3"?
Go zoomies or go home.
Probably fine though.
Probably not going to be enough. One taurus fan on high isn't enough to cool the Cummins in my buddy's Bronco; it'll overheat when we're towing during the summer.
How big is your radiator and where are you planning on putting it?
This is exactly the opposite of what I recommended. :laugh:
I told him that too and he called me dumb. I said, Oil temp & pressure, Tach, Water Temp, fuel pressure (somewhere, doesn't have to be on dash), and volt meter.(yes, oil pressure *and* temperature; that's one of the more sensitive issues with the motor I'll be running. It'll likely need an oil cooler as well.)
Exactly, and take good notes.
I think you and I bend tube the same way other than I also mark out every start and end of the bend with a little bit of math. It helps me replicate it on the other side.
:laugh: I called you dumb for what? The only gauges I don't have that you listed are oil temp and fuel pressure. Fuel pressure the way you have it setup is good enough, but oil temperature doesn't really concern me.
The big benefit to a 4.0? If I blow one up, throw another one in.
And honestly those are about the two least important ones to have. Knowing your speed is good for bragging rights but the actual number doesn't mean anything to me during a race; it's basically 'as fast as I can be going' limited by terrain, engine, etc.
RPM's, same deal. I want them as low as possible and as high as necessary, capped off by a rev limiter. You have to be comfortable with the idea of running your motor pretty wound-out for long periods of time. If I can upshift and cruise I will, if I gotta downshift to stop bogging the motor, I'll do that too...but that's not something a needle on a gauge is gonna give me any useful information about. The truck itself will tell you all you need to know.
Just sayin' :moon:
My father/uncle's advice was always just "floor it, when it stops making power, shift" so tach being in LOS probably isn't necessary.
Which version? I'm using a 31-spline output shaft, and if I do the short shaft kit there's no factory adapter housing.
Put it this way, convince me that a 4500 is better than a 435 and I'd do it regardless of cash.
Hmm...any suggestions on fans? I would think the extra coolant volume would help, no?
There are more 440s at my house then 4.0s
See my previous reply re: tach.
It's really kind of useless, the more that I think about it.
Ford I think?
My buddy had one behind a 350 (yes, ford trans behind chevy motor) and those were the two things he broke.
Every time you have to stop what you're doing because your trans is being stubborn about going into gear because it's not synchronized, you'll think, "I shoulda done a 4500".
The radiator and intercooler in the Bronco are transplanted from the same '94 Dodge that the motor came from. You've replaced the radiator in your truck (tee hee), it's probably the same size...you think you're gonna have more volume than that? And though his Cummins is pretty worked (BigHead wastegate, full banks turbo kit, 5" straightpipe, fuel plate, etc) it's probably still not as much horsepower as you're looking to make.
We fixed it by running dual Taurus fans (the shroud area was big enough to accomodate this) and we put a two stage electronic relay control so it only runs the second one if the motor temp gets beyond normal.
I wish I lived in a house where I had this 'problem'![]()
If any of you butt stuffers are looking to move, I think the house across the street from me is getting foreclosed. I can keep you updated when I find shit out if you'd like.
