Dundy
- Taunton, MA
STOP HIDING YOUR TRUE EMOTIONS!!!
Deal breaker right there.
Says the bald midget that wants me to hook him up with my sister(that lives with me).Deal breaker right there.
But it looks badass.
Meh, it's only 1st/reverse that isn't synchronized. Simple double clutch fixes that.
But yeah NV4500 would solve that. Not sure if it's enough to make me want to do it.
Probably about the same volume as that. But there are plenty of chargers/challengers out there running more horsepower on stock size radiators. So not sure how that works :dunno:
I'll probably run one anyway, it's easy enough to do and useful for diagnosing stuff. Just sayin it isn't something I need in front of me all the time.
I'm assuming you'll be running an MSD ignition box or similar, with an adjustable rev limiter?
It's enough to make me never not want to do it.
Plus having 5th gear is nice. (ask Adam how that was workin out.)
Are they running a stock radiator in a 10-second 1/4-mile pass or a 3-hour endurance race?
If any of you butt stuffers are looking to move, I think the house across the street from me is getting foreclosed. I can keep you updated when I find shit out if you'd like.
The only thing that sucks, is they usually go for about $800-1000. Then, on top of that, I'm guessing the 5th gear mainshaft fix is almost necessary?
There is one listed close to me for $600 but it's out of a gas truck. I'd then need whatever else to fix the mainshaft and get 29-spline output instead of 23-spline (don't trust 23-spline) and I'd probably just go 241/205 doubler like I mentioned earlier. Except for the fact that finding a 29-spline 241 is another $600-$800.
For the amount of time you'll spend in 5th gear, I wouldn't worry about it. I only did mine because I was changing from a 2wd diesel mainshaft to the 4wd gas mainshaft and had to do it anyway. From what I remember the parts were pretty economical; Rockland Standard Gear is a great place to deal with.
I have the 1-1/4" 10-spline input gear sitting around if you end up needing one.
sirius question.
has anyone seen a larger heim like 7/8" completely separate?
just seein all this talk of safety washers and heims falling apart.
ive seen tie rod ends come apart before and theres no way to put a safety washer on those and nobody is going around saying they are dangerous because that is such a rare occurence.
Newp.
I've seen ones that are sloppy as shit, like all the liner is completely worn away, and the ball is still in the middle. Especially for something like a tie rod where the loading is almost entirely from the side, I don't see a problem.
Unless you land on it hard enough to pull one apart, but you probably have bigger issues at that point.
Meanwhile my Dodge chucked a TRE in a parking lot.
maybe.would i be gay if i make a build thread when my jeep is already built? i got ninjas asking me for a link to my build thread. but i stopped doing that stuff like 2 years ago
