billyjp2
- Indian Orchard MA
atleast its not brown eye
I need to find a flush drain plug for my NP435 or else I can't take out my passenger side LCA bolt without first draining the trans. Either that or bolting the control arm up first then the transmission.
Put that on the list...I think it's 5/8-11 but I'll double check that tomorrow. Already found a bolt that might work on McMaster.
Sounds like chrysler OEM to me :thumbup:
What does? The size of the drain plug?
It's a Ford NP435...though I'm sure they didn't change the drain plug between models for each company (Ford, GM, and Dodge all used it).
can't get a socket on the cv joint front ds bolts
Last night it was pitch.What's your game?
And as a side topic for further discussion in the morning, any blackjack enthusiasts here?
I acutally was up early so I pulled the Jeep out and made sure I was good to go too.I'm in the same boat.These axles are staying just the way they are though.
Got the front axle all back together tonight, including a major clustershit on the driver side. Right now it's assembled...but that's the side with the slightly twisted stub shaft, and now it has a crossthreaded spindle and two different style spindle nuts on it. It'll all be replaced before the first race but for now, it's gonna need an impact gun to get those spindle nuts off. Thing's pretty well screwed.
Didn't have the metal I needed to do the new hydro-assist clamp, so the old one is back on again. That's easy enough to swap out once I get the right stuff though.
Doing the shocks tomorrow, and everything should be ready to go by Friday evening for the snow.![]()
3/8" NPT has an approximate OD of 0.675", where 5/8" would be 0.625".
Not sayin' that's what it is, but does that sound possible?
Bronco Graveyard had the spindles for ~$75.
Colin.
McMaster #4534K43. A whopping $0.90.
Shoulda just built it to clear......
Big people work harder, not smarter. If you were normal sized, you'd know that.:lecture:I would love to know how your brain works.
