THe NAC Lots-O-BFG KO2 Thread
Hmm, i jsut realized something I sold and dont have. I need new shackles.
you're chopping up a unibody and still need shackles?
:twak: DOING IT WRONG
with that logic, I'm doing it correctly :scottm:
yeah but too slowly :spin1: but at least no one can tell you to buy a kit for this!
As for that diff cover, it's pretty awesome but I've never seen a set of diff gears wear out due to anything except bearing problems or setup problems or too much go pedal. Maybe I'm missing something, but I figure if I change the lube when I'm supposed to, I'm already doing better than 99% of the driving public and my diffs will likely last forever with only bearing and seal replacements.
Bill was posting that for ****s and giggles.
In reality, you can overheat gears especially when towing. Doesn't usually happen in stock form but it is possible.
Uh oh... plans?
You already know my plans. I cannot be dissuaded :firedevil
I've seen a fair amount of trucks from the factory with heat sunk diff covers. Nissan Titan is all I can think of off the top of my head, though.
That's because they thought it would be a good idea to use a D44 as a rear axle in a half ton truck.
That was something I was unaware of. All I noticed was an aluminum heat sink...
LOL first three
my transfercase gets so hot it boils my spit on hot highway runs.
i thought this was weird until i went under friends jeeps and spit on thier transfer cases.
my 60 gets pretty warm too. but intents housing and thick ass cover doesnt dissipate heat too well...
That pic was at MaBell sometime last summer. July-ish I think...
I don't have any pics good enough to go in an avatar I don't think. I will continue being avatar-less for the time being. :thumbdn:
And my trans tunnel heats my Jeep quite a bit. My drivers side door is a little out of line so it bends the front fender in right in front of the door. I also have no speakers in the door. My buddy started pulling my bent fender out and I told him not to.. gives me a nice (and much needed) intake vent for a draft that comes through the speaker hole :D
I thought you were coming over to grab those tanks tonight?
Don't TOUCH that 2x6!!!
I need a decent amount for each side.
.!.:D.!. too late!!! you'll still get at least 6 ft. I may stop by later, if i get in the zone and actually start doing work, im not gunna wanna stop (i hoping this happens so i get something done)
Im not chopping anything, i getting my ass wheeling again by nacfest.
Didn't you have dovetail plans?
I do, up front. Since I dont wanna do any chopping out back (right now) I'll leave it with a fat ass and a skiny nose.
