themangeraaad
- Halifax, MA
First things first I wouldn't be chopping up a tailgate at all. I would be chopping up a Jeep to fit an MJ tailgate. Long story short I would be trying to install the tailgate using the stock MJ mounting hardware on the XJ. Then I would chop the lower half off the XJ hatch and try to make it close/seal like a bed cap would on an MJ. The goal would be to not alter the MJ tailgate at all so I could sell it if my project doesn't work... all modifications would be done to the XJ.
Alright, will try and find some piano wire somewhere.
I will ritualistically slaughter you if you chop up a perfectly good MJ tailgate :smsoap: :gag:
Fuel tank I wouldn't bother with unless it's 100% rust free - you can get them brand new for about a hundred bucks. The fuel sender assembly is the tough to find bit.
Rear window - use a torch and it'll be wrecked. Use the guitar string / piano wire windshield removal tool, preferably while someone else is holding it up because it'll fall out and break otherwise.
