Begster
- Cape Cod/Boston, Mass
Hahaha.
Very nice edit Rob.
Hahaha.
Very nice edit Rob.
I need to take a dump. I guess I should shoot it out in the toilet but that's where I ALWAYS do it. Think I should mix it up and poop on my television or something?
you could get a rc dump truck and deliver the goods to your nieghbors dorrstep
you're not actually taking a dump, you're leaving it.
Well that's why I was asking... I have a 2 dr and thought if there was some way to swap out the seat frame or use leather seats from some other 2 dr vehicle, maybe I wouldn't lose functionality of my back seat. I guess vinyl makes sense too. Damn, I was really hoping that I would learn something new to do.Huh, I guess that does look like leather in that picture.
They are vinyl seats, are stock, and fold forward because it is a 2 door, and you need some way to get the people into the back.
get a chop saw for sure. I was in the "man up and use your angle grinder" camp till yesterday, when I happened to see metal cutting abrasive discs that fit my chopsaw (which I had only used for wood previously) and I will never go back. So much easier to get straight cuts on whatever angle you want.
yeah, I probably will next time I hit the pawnshop, for now I'm only cutting the occasional piece of 1/8" angle or 1.5" pipe and I go really easy on it and take about 3 minutes to finish the cut.id upgrade to a saw designd for metal pretty quick, that would be ok for aluminum and occasionally thin steel but put anything thick in that and youll burn your motor out in 2 sec
and a good 15" chop saw will have a handy lil vice built into it so you dont get projectiles
Rob make sure you look at the base on that one before you purchase it. I was going to get the same one and the base just isn't up to par. I ended up with Milwaukee's 6180-20 (carefully, they also have a less desirable version with a different model number) for the same price as the Dewalt. I love the saw, plenty of power. I've cut two pieces of 2x4x.025" standing up (so about an inch thick material) at the same time and it had no issues. Anthony and Colin now also have that saw as well.
Some else to point out is the blades. I know it hurts to spend $9-11 on a blade, but the $3-4 ones just won't cut anywhere near as well. Make sure you have a spare or two on hand.
i heard a rumor that dana 30 and d44 yokes are the same. can i get some confirmation?
Rob make sure you look at the base on that one before you purchase it. I was going to get the same one and the base just isn't up to par. I ended up with Milwaukee's 6180-20 Anthony and Colin now also have that saw as well.
Thanks for the info, i will look into the Milwaukee
Snow.
I pulled up and it looked like she was on flat ground.
No, unfortunately. I got a hug and she told me "she owes me." But don't worry, I'll plant the seed. (hopefully literally as well as figuratively)
Oh, ya, I ordered RuffStuff frame stiffeners today...
DAMMIT
if only i was speaking to you instead of travis 16 hours ago we could have worked out a deal of sorts.
idk if my ruffstuff stiffys are going on my jeep or not
