THe NAC Lots-O-BFG KO2 Thread
70 rear = boat anchor/drag over pebbles
o yeah i forgot to add, i have 1 issue with putting the swaybar back on, i kinda sorta cut off the axle mounts
i actually got some work done on the rear bumper today:party:
got all the pieces i had cut and made tacked into place. gotta hit up airgas for some more sheilding gas and make a couple smaller pieces, then BAM, done.
i shouldnt have to grind too much of the fords with the right backspacing. theres also a chance i could put chevy outers out it too, then ill be able to clear 15's no problem.
Thanks to Ross for helping me press on the bearings on the Superiors today.
Hopefully the 44 will be ready to go by the end of next Monday.
fords are dual piston wich need a bit more grinding then the chavy or dodge caliper wich are single piston, i almost put a d60/stearling10.5 combo under the green jeep a few years back, if your gonna run 15's then go chevy outer and wheels with like 2" bs
hes not lying, ive had to grind the piss out of ford calipers and even the inside of the rim to fit 15s.
is the allthread 7/16 or the ID of the bolts on the eyes of the heims? i'm digging around mcmaster to make an order today for the linkage. also, about how long was the allthread? i know yours if from a 241 but its close enough to the 231 to make use of the adjustments in the heims
http://store.summitracing.com/partd...1&part=SUM-MSF7&N=700+400304+115&autoview=sku
Those are the ones that I got. I have some allthread as well the you can have. I had to buy 4 feet of it to get it and I used 6 inches of it. I used the 7/16 because the holdes for the heim match the holes for the linkage without the bushing.
Hey Billy, how's the WJ pump goin?
you ever seen the calipers from FTF's Mikes buggy, he took off a ton to clear 15's
yum.
i can do that too!!!
52" iroks!!!
