THe NAC Lots-O-BFG KO2 Thread
:D:D:D:D:D:D:D
got more done on the jeep today, motor mounts, ruffstuff cover and put the frt bumpstops back in, still got a few things left before wheelin this weekend should get most done after work tomorow
holy HELL there was traffic coming home from work today, thanks to two dipshits who got in a teeny fender bender and decided to take pictures of the scratch for the insurance company..... in the fast lane! grrr
Well, since people are talking about money and axles.
The way I look at it, I paid a sh*t ton of money to find out that I'm a retard if I break anything on my front 44.
mark, why do you put it so bluntly? did you not realize that was way overbuilt for 33s?
sweet axle colin. i need to post some pictures of my work today...
Oh, I knew it was overbuilt. I figured when building it, I might as well go all out, do all the work the first time around. I will say I don't think I realized the full extent of the over-builtness until it was fully done.
my plan for the evening:
eat, preferably quiznos
go to jeep
clean up the horrendous mess of tools in garage
pull of drums from d44 to fix the orientation (again), pack bearings with grease if i have time
oh mark there were 2 part numbers i've found for flowkooler water pumps - its different on quadratec and summitracing. do you know if htere is a difference?
Kyle- what brand are those shackles and whats the width of the metal?
Anthony - At what point do you stop and just say thats enough. I'm just curious not busting balls.
Billy - I think there was a question for you on the bottom of page 798
bump, theyre the RE 5" (~1.25" lift) shackles. look to be pretty stout, welded all the way around, zerk fitting, and .25" thick. they were $78 for the pair through fullsizexj on here
i'll make sure to come down BEFORE rush hour though, like leaving at noon instead. I'll let you know. off to work on the jeeeep
bump, i basically decide on what i already have and how much what i want to do costs...
the first thing i bought for my jeep was a step in the correct direction: the no-slip, then 31s all within 2 weeks of each other.
but basically the reason i still have stock axles is that i felt like for where i was going (no bigger than 35s for those axles) it was reasonable and also at the time i started building it i had no welder and next to no fab knowledge. i've learned a lot in the last couple years
Kyle those are not table decorations, there lift shackles, suposes to be installed in the rear of your jeep like in this pic
:D
when i got Mark's axle from ross it was in ruff shape, open diff, a little rusty and broken shock mounts, but after some mighty putty and a little buffing from a shamwow its locked and damn sexy
