THe NAC Lots-O-BFG KO2 Thread
k, i'll do that
what's your caster?
are your tires balanced?
Caster is 8* on the driver's side and 7* on the passenger side. I'm gonna dial it in to a low 7 next time I have time available.
I have no vibration at any speeds...
no vibes, just DW?
that is correct sir!
oh an no front driveshaft in either, that had a junk slip joint
hmmm.... have you tightened everything? what about control arm jam nuts? is the DW bump induced or is it between certain speeds?
it is bump induced at 40+ mph and if induced i have to slow to under 40...and every jam nut is tight.
hmmmm.... track bar bracket tight?
yup...
all the TRE's are good and the hubs are too?
yea checked all of that today. that's when I found the ball joints...
hmmmmmmm... sometimes hubs go bad and you can't see play... :dunno:... this is a good one. do you have a steering stabilizer?
what about the track bar joints?
took the track bar off 2 days ago to inspect the joints and I do not have a steering stabilizer. If it makes a difference both of the joints at the track bar are soft joints...
hmmm... and more hmm... do your angles match perfectly? bump steer without anything damping it i think could do it.
Rooster feathers!
if you jiggle the steering wheel, does anything clunk? or can you feel all the joints and have someone jiggle the wheel?
