THe NAC Lots-O-BFG KO2 Thread
HP is way better than LP. i'm glad you're going that route, travis.
78 no-go? :( refresh my memory where's the 77 at? heh
Mark...what years am I looking for, whats got cast and what's got welded mounts?
78-79 have cast mounts if they have wedges. 80 on is the TTB suspension, unless you have a heavy duty one that has a solid front axle.
the '77s in RI, and it comes with a 9", I think its the drivetrain.
76-77 are disk brakes, but that isn't a big deal as you will be switching to high steer anyways.
For the life of me, I can't remember which axles constitute leaf spring front. I think that may just be F250.
i ordered a compressor for my OBA last night. i know i should continue saving $ for the WJ parts and steel, but i might order lube lockers. sick of RTV.
:( gayyy TY for the info though, good sir.
any reason *not* to use a 44 from a 250?? my main concern is making sure that the stuff I already have will work on whatever axle I'm getting.
8 on 6.5 pattern, unless you swap parts around.
well the "plan" is to narrow it to EB width, turn the inner c's, and use my EB shafts that I've got, and then all the stuff that I currently have knuckles-out, I can't think of any reason it wouldn't work, but just thought I'd double check with whoever before screwing myself heh
very good, sir :)
check out the thread about member ratings in the member's area...
and check out the thread about tom wood's in the member's area. i guess i know what part of our stuff that we get at nacfest is :party:
I was gonna quote xcm's post and ask if he thinks he would avoid negative ratings after posting like that...but I refrained :laugh3:
i thought about it too, but i decided to be mature. he was starting a 13-yr old girl fight right there.
yeah, exactly :) +1 for travis avoiding subpar posting!!
:clap:
