Re: THe NAC Lots-O-Peanut Butter thread
I'll have it done before your nova or mj
Yawn
Yawn
MJ is staying 4.0
Alum 5.3
What a bitch
sounds expensive
I really hope you mean t56, a t5 would explode the first time you release the clutch
using one hand to steer the other to change gears one foot to control the throttle and the other to control the clutch all while screaming at the top of his lungs engine noises is too complicated for ross
he prefers to just smash the pedal scream out the engine noises while double fisting hot pocket. why do you think he rolls doing stupid easy stuff so much?
The part that was awesome is he can do a noise that sounds like a fan hitting a radiator for hours and not care.using one hand to steer the other to change gears one foot to control the throttle and the other to control the clutch all while screaming at the top of his lungs engine noises is too complicated for ross
sounds expensive
Anyone want a Miller 135 MIG?
That is awesomeMy 5.3 cost me $0, all aluminum with factory LS6 hipo heads and better rods/pistons
No, they want my Miller 180 MIG
Turns out it was just the fan shroud, it popped out of the lower clips and was just bouncing around off the fan blades.
