THe NAC Lots-O-BFG KO2 Thread
Just went out to measure my steering throw for ram assist. decided to start it for chitsngiggles. I noticed when up on jackstands when I reached full lock the steering would jerk and make noise.
Let the truck down and the power steering was working...
drove around and its still spotty though.
maybe it it will be mint if i leave it alone for another day lol.
How did you bleed the system Sam?
how I always do it. tires off the ground, lock to lock a few times, then let it sit for a bit. repeat as necessary. The thing is this pump didn't make a peep or move any fluid the other day.
sure there isnt still air trapped in there? maybe pull the rear tires off and let the resi sit way high and try to bleed it again?
the resi is the highest point in the system as is.
Ordering a high performance p pump from psc now regardless. Will be good to have down the road anyway.
so i pointed out that wheeling the disco was gigantic compared to a XJ and just got schooled.
wheelbase:
XJ: 101
Disco1: 100
width:
XJ: 68
Disco1: 71
length:
XJ: 167
Disco1: 178
they are a lot closer than i thought. its actually almost identical to a ZJ.
Foresters with a grill guard, roof rack, and a mild lift look almost exactly like a ZJ.
It's really confusing.
Youse guys that have messed with exhaust recently: know of a good source for a 3" ID 3 bolt flange? Summit has one or two, but they seem to be super pricy for what they are. The one currently off the Y pipe on my DT headers on the 5.9 looks bad, and I need to redo the exhaust from the headers back, so I figure now would be a good time to replace everything.
