... and you make fun of us for not driving shitboxes.
What did you do to the 5T this weekend?
I would like a nice car sometime but I would have to spend way more than I can afford. And I'm running out of things to replace on this piece of shit :laugh:
Remaining: rear axle, wiring harness (80% of it anyways...), seats/interior plastics/dash, front axle, control arms, coil springs, swaybar, some engine accessories, doors, 80% of the transfer case, and the chassis.
Replaced so far:
driveshafts
o2 sensors
full exhaust
engine
transmission
ECU
battery
alternator
PS pump
parts of wiring harness
entire front clip
heater core
SYE installed
trans crossmember
rear leafs
gas tank, twice
all brake lines
all brake everything, except the MC and booster
shocks all around
swaybar links
radiator
airbags (had none when I got it)
track bar
all tie rods
unit bearings
ujoints
balljoints
There is more on the list but I don't even remember everything anymore.
That's... about it. And the rear axle, seats, control arms, coil springs, and a few other things are likely next on the replacement list.
Then I'll probably get a clean straight rust free chassis and spend a marathon weekend moving everything over because I like pain and suffering.
I tore the whole top end off the motor. As of 1AM, the heads are back on and torqued, pushrods back in, still needs the rockers, manifolds, turbo, injectors, valve lash set, all 3 wires reattached (extremely complex electrical system on this vehicle), fuel lines reattached, cooling system refilled and an oil change. Hoping to have it ready for GTD this weekend.
