Begster
- Cape Cod/Boston, Mass
So I tried working on Rob's Jeep today to get it started. No crank, no signal going to the starter relay when you turn the key, fuel pump doesn't prime. I plugged in my old ECU, ignition switch, CPS, nothing made a difference. Checked fuses, swapped relays, partially installed a my old battery cables and harness to starer, still no change.
I even pulled out the weird mystery box from behind the steering column (after I tried switching the on/off switch to the on position).
I've now officially given up, anyone want it for parts let me know.
